donnie_f_s
#1 Posted : Monday, September 24, 2007 6:34:38 PM(UTC)
donnie_f_s
There's water coming from under the outer tub. It's a slow leak that is making the entire bottom of the tub wet. I was told that it was possibly the tub seal. Am wondering how difficult and if I need special tools to repair this. I am also wondering if it is worth repairing this model or should I just plan to replace the washer. Advice and imput is greatly appreciated. Thanks, Donnie
#2 Posted : Tuesday, September 25, 2007 2:59:28 AM(UTC)
Best to fix this before the tranny fails from the water leak.
Pull front panel and confirm water leak above tranny. If so, go to Appliance repairs, Appliancehelp, Appliances, repairs to dryers washers dishwashers fridges repairs microwaves ge maytag kenmore frigidaire westinghouse inglis, appliance how to take apart information, purchasing an appliance help, model number help, for repair info. It is a rather involved repair and you will need a special spanner wrench. Click on your model # for parts info.
Kitty
#3 Posted : Wednesday, June 4, 2008 5:38:37 PM(UTC)
Kitty
I have the same problem.
It seems like water is driping from around the 8" diameter Trany housing (Minor Leak) The bigger problem is water leaking between the 18" seam between the plastic outer tub and the steel bottom. Maytag model Number MAV6357AAW.
Is this the same seal that you replaced.
GE Washer leaks after sitting? (Washer Repair)
by redjada 4/11/2018 2:46:00 PM(UTC)
Washer leaks on front door (Washer Repair)
by robertkral1 10/4/2017 11:41:47 AM(UTC)
Washer leaks and fills drain tray (Washer Repair)
by boberp 3/13/2016 7:27:42 AM(UTC)
Kitchenaid Dishwasher Leaks at Float (Dishwasher Repair)
by macd2x 11/8/2015 7:29:26 AM(UTC)
Washer leaks (Washer Repair)
by DIYChallenged 9/14/2015 10:15:27 AM(UTC)
Dishwasher leaks front door (Dishwasher Repair)
by kbratto 8/26/2015 9:53:11 AM(UTC)
New Maytag top load Washer Leaks in Front (Washer Repair)
by Gadgetmonster 7/10/2015 9:11:53 AM(UTC)
Maytag Washer leaks at bottom tub seal (Washer Repair)
by Stilltrying 6/22/2015 5:52:31 PM(UTC)
Kenmore portable washer leaks (Washer Repair)
by Jimisand 3/9/2015 10:38:25 AM(UTC)
Whirpool duet washer leaks water+detergent after load finished (Washer Repair)
by waylo 1/25/2015 9:47:32 PM(UTC)
Washer Leaks while filling up .. Large Loads Only (Washer Repair)
by martynva 7/26/2014 3:17:06 AM(UTC)
Amana Washer Leaks (Washer Repair)
by axis9313 6/24/2014 3:50:30 PM(UTC)
Frigidaire Gallery Washer Leaks at Bottom (Washer Repair)
by calvin83 2/5/2014 3:44:39 PM(UTC)
GE Front load washer leaks on rinse cycle fill (Washer Repair)
by damadczar 10/21/2013 3:26:51 PM(UTC)
Washer leaks water while filling tub (Washer Repair)
by 2WHIRLPOOLSCLW 5/26/2013 4:57:28 PM(UTC)
