Gremlins
#1 Posted : Tuesday, October 26, 2010 5:12:57 PM(UTC)
Gremlins
Need advice,
Washer wont spin. I found while troubleshooting on the motor an led light was flashing 6 times which shows locked rotor.
Is there anything else this could be before I purchase a new motor/inverter?
BabsGar
#2 Posted : Tuesday, October 26, 2010 5:32:52 PM(UTC)
BabsGar
Originally Posted by: Gremlins Go to Quoted Post
Need advice,
Sounds like the pump needs replacing
applianceman
#3 Posted : Wednesday, October 27, 2010 5:47:52 AM(UTC)
applianceman
See if there is in fact a locked rotor. Try to turn the plulley by hand and if it will turn freely then the rotor is not locked. Try clearing the code as decribed on this page HydroWave GE Washer Repair Guide then if the error comes back replace the motor.
If the pulley will not turn then you have to see if it is the motor or the shaft and tube (sifter). Remvoe the belt and see if the motor is stuck or the big pulley is suck. If the motor is stuck the motor is bad and if the big pulley is stuck then the shaft and tube is the problem.
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
Whirlpool LTE6234DQ2 Wont Spin (Washer Repair)
by kelgun 12/7/2023 2:53:34 PM(UTC)
my fully automatic washer,(top loader) WONT SPIN (Washer Repair)
by johnsail2000 4/14/2023 8:51:18 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
washer wont spin (Washer Repair)
by allen9258 4/8/2018 11:08:33 PM(UTC)
GE top load wont spin (Washer Repair)
by NOELLE.EUAN 10/15/2017 5:03:37 PM(UTC)
Hotpoint wont spin or drain (Washer Repair)
by Snowostrich 7/1/2017 2:53:32 PM(UTC)
by malakye 3/5/2017 1:18:25 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
Kenmore wont spin or drain. no noise. Lid switch does click. (Washer Repair)
by DCAJR1 8/17/2016 12:09:50 PM(UTC)
Wont spin on *some* settings (Washer Repair)
by merkman 7/18/2016 7:15:38 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytage wont spin (Washer Repair)
by Mike055 12/10/2015 11:15:41 AM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
