My Maytag Neptune has stopped draining all the water out after the spin cycle. It works fine but the clothes are still wet when removing them for dryer. Do I need to take machine apart or just look somewhere for my problem? Any help would be greatly appreciated.
You probably need to check the motor to see if it is actuall going into high spin and check the motor control board too. Nat
