dryer wont start, sounds like timer is running, already checked the door switch,thermal fuse, and I think I checked the drive motor properly. start switch seems to work because i have power at motor. what next???
If there is power at the motor but it does not start, then the problem is a bad motor. Here you can find the wiring diagram for the dryer. - The part number for the motor is AP3094245 Here are the break down diagrams for the Whirlpool dryer Model LGR6848AW0Gene.
thanks for your time Gene !!
bart
