Dryer will not heat. It runs through cycle like normal just doesn't heat up. Husband checked all wires. What else can he check?
First check to make sure there is 220V at the breaker and plugin. Then remove the rear panel and check the thermostats with both wires diconnected from it. Use an ohm meter for this and test for continuity. It's best to check one thermostat at a time so the wires can be put back in the correct spot. Most likely it will be one of the themostats. Part number AP3094244. keep us posted as to your findings. Nat
