bwilkins
#1 Posted : Tuesday, October 14, 2008 12:56:59 PM(UTC)
bwilkins
I recently replaced the valve and still no ice. It still doesn't seem like water is getting to the ice maker. Am I missing something? Thanks in advance.
v2k04
#2 Posted : Tuesday, October 14, 2008 1:22:00 PM(UTC)
v2k04
Did you check the fill tube going into icemaker to see if it was frozen?
bwilkins
#3 Posted : Tuesday, October 14, 2008 4:00:55 PM(UTC)
bwilkins
Do you mean the plastic tube that feeds into a plastic square on the back of the ice maker? If so, how do I tell if it's frozen up?
v2k04
#4 Posted : Wednesday, October 15, 2008 3:19:28 AM(UTC)
v2k04
You almost have to removwe the ice maker to see it. depending on the ice maker and the age of the frig Ge had mechanical ones and those are now obsolete and replaced with electronic ones The electronic ones aren't servicable but the mechanical ones are.you can distingwish the two the newer style will have a green power lite on them while the others you can pull the white cover off and see a white plastic gear in the center. If thats the kind you have you can force cycle the ice maker by pulling the ejector rod towords you or take a screw driver and turn the little gear so it stsrts to run. look at the big gear to see if its missing a tooth or two. if the icemaker cycles and fills by manually doing it more than likely you have a bad switch inside the head if you do you can take it apart and repair it but be careful cause things go flyin everywhere lol just replace it with a new one The part number is something like a WR31x10061 or close to that cant remember off the top of my head lol
bwilkins
#5 Posted : Wednesday, October 15, 2008 5:18:33 AM(UTC)
bwilkins
Thanks for the help.
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
