labinsky
#1 Posted : Tuesday, October 14, 2008 9:28:29 AM(UTC)
labinsky
The tub does not spin any more. I imagine it's a belt or switch. I've searched for parts but the search doesn't find this model.
v2k04
#2 Posted : Tuesday, October 14, 2008 9:33:20 AM(UTC)
v2k04
If it pumps and doesn't spin you need a coupler Whirlpool part 285753 if the machine is totally dead when it goes into a spin cycle its the lid switch. There are other varibles involved this I gave out is most common, If the coupler is broken it wont wash either all the machine will do is fill and pump and make a grinding noise while its doing it
labinsky
#3 Posted : Tuesday, October 14, 2008 3:18:38 PM(UTC)
labinsky
Thanks a lot, v2k04!
#4 Posted : Wednesday, October 15, 2008 1:15:15 PM(UTC)
In order to provide most accurate advise we need the complete model number of the washer. You can find it under the lid. The model number you posted is not a valid Whirlpool model number.
Ge washer tub not spinning (Washer Repair)
by Rconner86 3/17/2022 7:32:41 PM(UTC)
LG Steam Washer. Tub not spinning. (Washer Repair)
by LGUser 5/28/2013 1:33:49 PM(UTC)
Washer tub not spinning - no lights on motor control board... (Washer Repair)
by dperk 11/28/2012 3:04:55 PM(UTC)
Tub not spinning with clothes (Washer Repair)
by Biffspagnutz 5/16/2011 10:13:08 PM(UTC)
clothes Washer Tub Not Spinning (Washer Repair)
by Dale7905 3/16/2010 7:33:00 AM(UTC)
Whirlpool Agitator & Tub Not Spinning (Washer Repair)
by muffy94 1/9/2010 11:45:39 PM(UTC)
Water draining but tub not spinning (Washer Repair)
by Coastal_Mapper 11/17/2008 8:46:15 AM(UTC)
