The tub does not spin any more. I imagine it's a belt or switch. I've searched for parts but the search doesn't find this model.
If it pumps and doesn't spin you need a coupler Whirlpool part 285753 if the machine is totally dead when it goes into a spin cycle its the lid switch. There are other varibles involved this I gave out is most common, If the coupler is broken it wont wash either all the machine will do is fill and pump and make a grinding noise while its doing it
Originally Posted by: v2k04  If it pumps and doesn't spin you need a coupler Whirlpool part 285753 if the machine is totally dead when it goes into a spin cycle its the lid switch. There are other varibles involved this I gave out is most common, If the coupler is broken it wont wash either all the machine will do is fill and pump and make a grinding noise while its doing it Thanks a lot, v2k04!
In order to provide most accurate advise we need the complete model number of the washer. You can find it under the lid. The model number you posted is not a valid Whirlpool model number.
