tonypro@ooptonline.net
#1 Posted : Wednesday, October 8, 2008 6:05:20 AM(UTC)
I have a ge artica model psc23ngnaww that has both lights functioning freezer and refrigerator when the door is opened warm air is circulating thru the unit the compressor fan on the bottom is running and i hear either the water solenoid or the compressor click once. i was told by a hvac tech servicing the ac that it was the compressor was humming (a good thing by him) the front control panel in the refrigerator is dead, it has no display for temp settings, etc. The control panel for the thru the door water has power and responds to pressing.There was a power surge that took out the motherboard on the central ac unit the same time this went down. I viewed both the main motherboard in the back and the smaller board behind the display panel and neither show any apparent burn marks. Do I need to replace the motherboard, the control board circuitry or both? I also understand that if i replace the motherboard, certain other componets (thermisters) need to be replaced, because a shorted thermister will burn out the new board But which ones and where are they?
#2 Posted : Wednesday, October 8, 2008 8:54:40 PM(UTC)
I would start with the main control board replacement. I do not think that any thermistors are damaged because they are not an electronic parts.
- The part number for the main control board is AP3950129
In order to prevent such problems I would recommend to install a power surge protector designed for appliances.
GE Artica Not making ice (Refrigerator & Freezer Repair)
by gr8filed 1/16/2016 7:02:48 AM(UTC)
GE Artica SBS barely cooling (Refrigerator & Freezer Repair)
by spam 8/1/2015 12:20:38 PM(UTC)
GE Artica Freezer/fridge no cold (Refrigerator & Freezer Repair)
by 1810garym 1/13/2012 7:54:16 AM(UTC)
GE Artica Fridge Keeps Cooling (Refrigerator & Freezer Repair)
by toch 1/7/2012 1:39:45 PM(UTC)
GE Artica Top Freezer Refrigerator: refrig and freezer not cold (Refrigerator & Freezer Repair)
by bigman812 11/12/2011 10:57:31 AM(UTC)
GE Artica door dispensor dos not work (Refrigerator & Freezer Repair)
by pvconnect 11/21/2010 12:54:20 PM(UTC)
GE Artica ice blockage issue (Refrigerator & Freezer Repair)
by kleverkn 10/15/2010 4:57:06 PM(UTC)
GE Artica problem (Refrigerator & Freezer Repair)
by dplin2001 4/2/2010 4:53:52 AM(UTC)
GE artica profile no water @ icemaker (Refrigerator & Freezer Repair)
by bmdt 3/9/2010 4:39:53 PM(UTC)
GE Artica PSH23SGAP doesn't stop running (Refrigerator & Freezer Repair)
by heymatey 11/25/2009 12:55:36 PM(UTC)
GE Artica leaking water from Ice Maker (Refrigerator & Freezer Repair)
by candypwhite 10/5/2009 11:48:40 AM(UTC)
GE Artica Freezer won"t defrost (Refrigerator & Freezer Repair)
by smithrock 11/29/2008 10:45:06 AM(UTC)
GE Artica Profile Down (Refrigerator & Freezer Repair)
by hemihearse 10/17/2008 9:49:59 AM(UTC)
GE Artica Ice Maker / No Ice (Refrigerator & Freezer Repair)
by fbaron3 7/2/2008 8:45:15 PM(UTC)
GE ARTICA rattling noise (Refrigerator & Freezer Repair)
by Kwing Lee 1/25/2008 7:59:39 PM(UTC)
