gr8filed
#1 Posted : Saturday, January 16, 2016 7:02:48 AM(UTC)
gr8filed
Hi, I Have A Ge Arctica Fridge That Has Stopped Making Ice. I Turned The Ice Maker Off For A While Than Tried To Reset It By Moving The Arm Back And Forth To No Avail. When I Turn The Maker On It Flows Water For Only 1 Second Than Stops. I Suspect The Water Valve Has Failed. I Am Having A Problem Locating The Correct Part Number For It. Any Suggestions ?? Do You Think I Am On The Correct Path. Thanks, Eddie
gr8filed
#2 Posted : Saturday, January 16, 2016 3:59:40 PM(UTC)
gr8filed
I also noticed that the green light is now flashing on the icemaker . it has been turned on and off several times but light still flashes
