Kessler
#1 Posted : Saturday, September 25, 2010 9:01:33 AM(UTC)
Kessler
First we thought it was the belt...wrong.. We noticed heat coming into tumbler getting really hot. My son thinks we need to replace thermostat #8318268. any help is appreciated...
sidfink43
#2 Posted : Tuesday, September 28, 2010 4:23:33 PM(UTC)
sidfink43
I assume the drum is turning.
You need to open it up and clean out the internal lint chute/vent and external vent and make sure the fan is working. If you still have the problem try changing the operating thermostat.
Kessler
#3 Posted : Tuesday, September 28, 2010 5:40:02 PM(UTC)
Kessler
:mad: DRUM IS NOT TURNING AND WE HEAR NO HUMMING FROM THE MOTOR WHEN WE PUSH THE START BUTTON ? :confused:
sidfink43
#4 Posted : Wednesday, September 29, 2010 4:47:31 AM(UTC)
sidfink43
If the heat is coming on but the dryer will not turn then you have a problem with the motor and its wiring and it is time to get a new dryer.
If the heat is not coming on, check the thermal fuse, the door switch and the start switch.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
