joz
#1 Posted : Thursday, September 23, 2010 9:21:14 AM(UTC)
joz
Whirlpool gold ultimate care gas dryer. dryer runs but does not get hot to dry the clothes. I've tried all different dryer settings and the problem is the same. Help me out. Thanks
reliable bud
#2 Posted : Thursday, September 23, 2010 1:25:23 PM(UTC)
reliable bud
does the dryer heat but not dry or does it not heat if it heats but wont dry check your dryer vent if it is restricted it will heat but can't get the moist air out so it wont dry if it is not heating there are several things it could be does the igniter come on but no flame or does the igniter not even come on no igniter check the thermal fuse and/or thermostat if the igniter does come on check the gas valve coils or the gas valve (assuming the gas is turned on i've been out to a house that the gas was turned off accidentally)
#3 Posted : Thursday, September 23, 2010 4:40:02 PM(UTC)
If the dryer does not heat at all, you can find some useful information in one of our previous threads: http://forum.appliancepartspros...3-no-heat-gas-dryer.html
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GGQ8858EQ0 | AppliancePartsPros.com
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Whirlpool Gas Dryer motor overheating - shuts-off (Dryer Repair)
by animateme 9/19/2019 11:59:22 AM(UTC)
Whirlpool gas dryer (Dryer Repair)
by JoAnninWV 5/7/2017 8:06:39 PM(UTC)
Whirlpool Gas Dryer heating intermittently, timer not working (Dryer Repair)
by christyhecht 5/2/2017 10:50:15 AM(UTC)
Whirlpool Gas Dryer screaching noise at first, then stops mid cycle (Dryer Repair)
by SRALPH 12/14/2016 11:40:34 AM(UTC)
Whirlpool Gas Dryer Takes Too Long (Dryer Repair)
by bijalshah01 9/28/2016 5:28:12 PM(UTC)
Whirlpool Gas Dryer Heating Problem (Dryer Repair)
by rinkugaya 9/24/2016 3:17:35 PM(UTC)
Whirlpool gas dryer heating issues/gas smell (Dryer Repair)
by Houseforsaken 8/8/2016 1:24:58 PM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
Need Wiring Diagram for Whirlpool Gas Dryer (Dryer Repair)
by ToddErickson 2/2/2015 4:11:08 PM(UTC)
Whirlpool gas dryer only heats for the first 5-10 minutes of cycle (Dryer Repair)
by Peter Wood 9/18/2014 7:28:53 PM(UTC)
Whirlpool Gas Dryer LP to NG (Dryer Repair)
by kyle_8888 4/10/2014 9:49:37 AM(UTC)
Whirlpool Gas Dryer - heat won't stay on (Dryer Repair)
by tubegeek 3/11/2014 1:10:32 PM(UTC)
by jeswon 12/16/2013 6:55:50 AM(UTC)
by miller42 9/4/2013 6:43:14 AM(UTC)
