ZMANIA
#1 Posted : Wednesday, September 22, 2010 6:03:19 AM(UTC)
ZMANIA
Hi, The Food In The Fridge Keeps Freezing. I Made Sure The Diffuser Wasnt Stuck Open. It Helps Turning The Freezer Up To The Coldest Temp, But The Fridge Still Runs Too Cold At Around 30 Degrees. The Refrigerator Is Set To The Lowest Setting As Well. Any Suggestions.
Thank You
#2 Posted : Wednesday, September 22, 2010 6:27:31 AM(UTC)
Sorry but I do not understand why you would "It Helps Turning The Freezer Up To The Coldest Temp" when it is too cold. I would have thought the opposite would be the way to go.
Check the freezer temperature. It should be between 0 and 5 degrees F.
If it is freezing things only at the bottom of the fresh food section.
Check hat the lower vent between the sections is clear.
Check that the evaporator fan is running.
Help - fresh food freezing up! (Refrigerator & Freezer Repair)
by Robd0728 1/12/2015 7:33:15 AM(UTC)
Food freezing in refrigerator (Refrigerator & Freezer Repair)
by Elaine J 9/12/2013 7:10:30 AM(UTC)
Food freezing in fresh food side.............. (Refrigerator & Freezer Repair)
by rkiburis1 9/24/2012 6:41:16 AM(UTC)
Fresh food freezing, temp display shows high temp (Refrigerator & Freezer Repair)
by kartracer 7/23/2012 9:10:00 AM(UTC)
fresh food freezing (Refrigerator & Freezer Repair)
by pterry 3/1/2012 4:52:48 AM(UTC)
food freezing in crisper drawer (Refrigerator & Freezer Repair)
by stockm 7/31/2011 4:31:26 PM(UTC)
Food freezing in main compartment and top produce drawer (Refrigerator & Freezer Repair)
by jrhtools 7/1/2011 12:39:35 PM(UTC)
by wapiwulo 1/7/2011 3:07:39 PM(UTC)
by stwoadis 11/24/2010 8:40:33 AM(UTC)
Food Freezing in fridge section (Refrigerator & Freezer Repair)
by aplprobs 10/26/2009 11:16:27 AM(UTC)
GE Arctica Food freezing on shelves by air tower (Refrigerator & Freezer Repair)
by Arctica28 5/26/2009 7:27:07 PM(UTC)
food freezing in refridgerator (Refrigerator & Freezer Repair)
by vabug72 4/3/2008 11:13:48 AM(UTC)
