jrhtools
#1 Posted : 14 years ago
jrhtools
Hello, I have aproblem with food freezing in the main compartment and top produce drawer in our Maytag MZD2768GE.
#2 Posted : 14 years ago
Measure the freezer temperature and post. Should be below zero if fridg running all the time. Critical to get a reading after the temperature has stabilized.
jrhtools
#3 Posted : 14 years ago
jrhtools
Hello, the temperature in the freezer compartment shows to be 10 degrees below zero. What should I check next?
Thanks,
#4 Posted : 14 years ago
You probably have a bad cold control AP4070269
jrhtools
#5 Posted : 14 years ago
jrhtools
Where would I find the cold control and how to check it?
#6 Posted : 14 years ago
Behind the control panel where the temperature control knob is. Make sure to route the new sensing wire exactly where the old one was. Symptoms show a bad control. Try spraying with a non-residue contact cleaner available at Radio Shack, might un-stick it.
jrhtools
#7 Posted : 14 years ago
jrhtools
Hello, I changed temperature control which fixed freezing problem in main refrigerator compartment.The top produce drawer will change from a setting above freezing to 25 degrees and freezes food. Any suggestions as to what I need to replace to fix this problem?
John
