The front 2 burners will not lite, The ceramic around the igniter appears to be cracked. How do I remove the burners to get to the igniters ?
Steve
The ignitors for the top burners is attached to the valves, which are located behind the knobs & front panel. Nat
How do I access the igniters ??
Look at this breakdown. Model MGS5770ADW if you look at page 5 which is the top you can see pretty much how to get into the controls. Nat
I looked at page 5, However I am at a loss. The igniter I am looking to replace is on page 3 (#9 ) & the part # is ap375912.
I found the igniter on page 3 (model MGS5770ADW) & I am at a loss at how to access this part it appears as if I have to remove the burner to get to the igniter. How???
Sorry wasn't thinking about that one... Use a wrench(large) and I would recommend padding it so you don't bend the cap, turn clockwise on the cap about 1 1/2 " to loosen, you will hear some crunching & grinding probably, it's normal. Then you should be able to lift the burner straight up, disconnect the wires. remove the screw one each burner and use a putty knife about 2 inches from each corner, between the top & front to release the clips and raise the top.
Nat
