steve234
#1 Posted : Thursday, October 2, 2008 7:45:46 AM(UTC)
steve234
The front 2 burners will not lite, The ceramic around the igniter appears to be cracked. How do I remove the burners to get to the igniters ?
Steve
libertyappl
#2 Posted : Thursday, October 2, 2008 8:04:22 AM(UTC)
libertyappl
The ignitors for the top burners is attached to the valves, which are located behind the knobs & front panel.
Nat
steve234
#3 Posted : Thursday, October 2, 2008 8:16:07 AM(UTC)
steve234
How do I access the igniters ??
libertyappl
#4 Posted : Thursday, October 2, 2008 8:19:59 AM(UTC)
libertyappl
Look at this breakdown. Model MGS5770ADW if you look at page 5 which is the top you can see pretty much how to get into the controls.
Nat
steve234
#5 Posted : Thursday, October 2, 2008 8:39:54 AM(UTC)
steve234
I looked at page 5, However I am at a loss. The igniter I am looking to replace is on page 3 (#9 ) & the part # is ap375912.
steve234
#6 Posted : Thursday, October 2, 2008 8:54:33 AM(UTC)
steve234
I found the igniter on page 3 (model MGS5770ADW) & I am at a loss at how to access this part it appears as if I have to remove the burner to get to the igniter. How???
libertyappl
#7 Posted : Thursday, October 2, 2008 9:00:09 AM(UTC)
libertyappl
Sorry wasn't thinking about that one...
Use a wrench(large) and I would recommend padding it so you don't bend the cap, turn clockwise on the cap about 1 1/2 " to loosen, you will hear some crunching & grinding probably, it's normal.
Then you should be able to lift the burner straight up, disconnect the wires. remove the screw one each burner and use a putty knife about 2 inches from each corner, between the top & front to release the clips and raise the top.
Nat
All igniters sparking (Oven Repair (including Ranges and Cooktops))
by stevekauss 4/30/2024 11:43:18 AM(UTC)
Removing igniter from thermador star (Oven Repair (including Ranges and Cooktops))
by Guest 2/24/2024 9:17:28 AM(UTC)
Maytag Double OVen Model MGR6875ADW- Igniter wont stop ticking (Oven Repair (including Ranges and Cooktops))
by gnieciag 10/15/2023 1:53:42 PM(UTC)
gas igniter troubleshooting (Dryer Repair)
by siberian72 10/10/2023 3:40:20 AM(UTC)
DCS 6 burner range igniter issue (Oven Repair (including Ranges and Cooktops))
by Dcsovenrepairguy 7/1/2023 12:42:26 PM(UTC)
Electrolux Gas stove igniter (Oven Repair (including Ranges and Cooktops))
by Guest 2/10/2023 10:22:25 AM(UTC)
DCS RGT-366-N burner igniter clicking (Oven Repair (including Ranges and Cooktops))
by Guest 1/21/2023 7:22:13 PM(UTC)
Broiler igniter issue (Oven Repair (including Ranges and Cooktops))
by Nubthumb 7/20/2022 4:36:27 PM(UTC)
igniter does not glow (Dryer Repair)
by Smatt 11/27/2021 2:32:24 PM(UTC)
Whirlpool GW397LXUS06 - 1 igniter not working (Oven Repair (including Ranges and Cooktops))
by TommyBoy2323 2/14/2021 8:56:10 AM(UTC)
Jenn-Air JCG9536ADS gas cooktop igniter behavior (Oven Repair (including Ranges and Cooktops))
by tedshred 12/1/2020 2:50:11 PM(UTC)
Maytag - Igniter will not glow (Dryer Repair)
by swatosh 11/13/2019 7:39:01 PM(UTC)
BOSCH Vision 500 Gas (NG) Dryer Model #WTVC6530UC/11 - igniter won't light, rapid clicking sound (Dryer Repair)
by KenBradley 8/11/2019 7:30:53 PM(UTC)
SF395LEEB igniters on the right side do not work (Oven Repair (including Ranges and Cooktops))
by Joepre 7/28/2019 5:56:31 AM(UTC)
SF395LEEB igniter question (Oven Repair (including Ranges and Cooktops))
by Joepre 7/28/2019 5:54:30 AM(UTC)
