cbmjb
#1 Posted : Friday, September 26, 2008 9:31:14 AM(UTC)
cbmjb
This might seem like a very basic question but I have never had one apart before.
This is a Whirpool style module. I have a replacement module on the way here. I have to transfer the cable (easy) and the on-off arm.
The back end of the old arm is easy to remove, but I am having trouble with the front end where it goes into the controller. How is it attached? Is it just a push fit or is there a hook or other feature to hold it in place?
I don't want to break or bend anything by being heavy handed in trying to disengage it. It just might be stuck or it might be secured somehow. How do I get it out. If I had a new one coming I could see what that hidden end looks like.
Thanks Charlie
libertyappl
#2 Posted : Friday, September 26, 2008 9:39:44 AM(UTC)
libertyappl
Charlie
They use so many different ones can you post your model number and the IM part number.
Nat
cbmjb
#3 Posted : Friday, September 26, 2008 10:32:12 AM(UTC)
cbmjb
Originally Posted by: libertyappl Go to Quoted Post
Charlie
Nat
The fridge is an Amana bx22tw
The label on the ice maker has IM #S 10S 626639
Hope these help
libertyappl
#4 Posted : Monday, September 29, 2008 5:04:18 AM(UTC)
libertyappl
Charlie,
It looks like it just slides in.
Here is the breakdown on your unit. Model BX22TW
Nat
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
Just need a screw for the ice maker arm, not whole assembly (Refrigerator & Freezer Repair)
by MCB223 5/2/2023 4:12:51 PM(UTC)
Frigidaire Ice Maker Arm won't move (Refrigerator & Freezer Repair)
by Guest 7/10/2022 6:18:09 PM(UTC)
Ice maker arm works, but no water (Refrigerator & Freezer Repair)
by dean8433 11/16/2021 10:05:30 AM(UTC)
Ice Maker Arm not returning all the way back dow! (Refrigerator & Freezer Repair)
by Ruff 11/3/2015 2:47:52 PM(UTC)
Ice maker arm shut off (Refrigerator & Freezer Repair)
by fixmenow 12/26/2008 12:22:58 PM(UTC)
ice maker arm won't drop to start harvest (Refrigerator & Freezer Repair)
by mikerodg 10/27/2008 10:48:59 AM(UTC)
