This might seem like a very basic question but I have never had one apart before.
This is a Whirpool style module. I have a replacement module on the way here. I have to transfer the cable (easy) and the on-off arm.
The back end of the old arm is easy to remove, but I am having trouble with the front end where it goes into the controller. How is it attached? Is it just a push fit or is there a hook or other feature to hold it in place?
I don't want to break or bend anything by being heavy handed in trying to disengage it. It just might be stuck or it might be secured somehow. How do I get it out. If I had a new one coming I could see what that hidden end looks like.
Thanks Charlie
Charlie They use so many different ones can you post your model number and the IM part number. Nat
Originally Posted by: libertyappl  Charlie They use so many different ones can you post your model number and the IM part number. Nat The fridge is an Amana bx22tw The label on the ice maker has IM #S 10S 626639 Hope these help
Charlie, It looks like it just slides in. Here is the breakdown on your unit. Model BX22TWNat
