My Ge Profile Is Always Freezing Up, I Changed The Heater, And Main Board On Back, And Is Still Freezing Up, Help Me Please!!!
Did you replace the defrost thermostat,AP3796802, a small, round device clipped to the evaporator coils.
No Do You Think That Could Be The Problem?
Ninety percent of the time, that's your problem, second is the defrost heater. You can confirm by temporarily shorting the wires to the thermostat, then force defrost with a jumper to the power connector on the motherboard. Unplug fridg, remove the 3 pin power connector and note which pins go to the pc board pins def. and line. Put a jumper between the mating pins on the connector, then plug in the fridg, should now defrost
Thanks I Will Try That Tonight And Let You Know If It Works...
Online shopping has been a trend now, so if you want to buy cheap boots isn`t a problem. The important question is what kind of boots style you like, in order to show it in front of your loved person? If so, the best quality and cheap boots is essential. our company Ugg boots not only beautiful but also very good quality,that is why in winter, best choices for women boots must be ugg boots. So where can buy best quality and cheap ugg boots. It is the focus of this article. First of all,the Internet so developed, it is also more stores of ugg boots will dazzling you, right? So hard to get one pairs nice boots to fited yourself. You have to sure your size, color, or even boot`s weight you have to consider too. When you think about the appearance of the boots, then you can start shopping. Here in ugg,ugg boots,cheap ugg boots,ugg boots online-www.ugg5803.com you can find all the newest ugg boots, and sizes are also able to choose, as long as you know your size. If you want to get big quantity of ugg boots or wholesale ugg boots,you also can choose from ugg,ugg boots,cheap ugg boots,ugg boots online-www.ugg5803.com. All the ugg boots are designed by the designer, using a high-grade suede material. Also ugg boots been made exquisite, so it can been a birthday gift or Christmas gift too !Their contact email is:service@ugg5803.com.
Do this test when the compressor is running and supplying power to the connector, just unplug fridg. first.
Originally Posted by: richappy  Do this test when the compressor is running and supplying power to the connector, just unplug fridg. first. could you please walk me thru what to do to test the defrost heater just to be sure im doing it right?
Just as I said, temporarily short the wires that went to the defrost thermostat, make sure the fridg compressor is running, then remove the cover to the motherboard in back, locate the 3 pin power connector, unplug fridg, unplug connector and put a wire jumper between mating pins that go to the terminals marked line and def.
