Casey0053
#1 Posted : Saturday, September 11, 2010 4:13:05 PM(UTC)
Casey0053
The outside top and sides of the refrigerator and freezer are hot to the touch and the refrigerator is not cooling that great. The temp is set all the way up. Everything freezes in the freezer except ice cream. It only gets mid way. Any suggestions before I call a repairman? I would like an idea of the problem so I won't get taken. Thanks for any help.
#2 Posted : Sunday, September 12, 2010 4:29:25 AM(UTC)
Could not find a BW6, following is for a BW7, parts breakdown.
Replacement parts for FRIGIDAIRE FRT21G4BW7 Frigidaire/refrigerator | AppliancePartsPros.com
A hot case is usually due to dirty condenser coils under the unit or the condenser fan not running.
Casey0053
#3 Posted : Sunday, September 12, 2010 11:22:35 AM(UTC)
Casey0053
Thank you. I cleaned it and will wait and see. I also verified on the inside plate and it is a BW6.
Need Help Identifying Part Manufacturer (Oven Repair (including Ranges and Cooktops))
by anonymous24 5/1/2024 3:25:51 PM(UTC)
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
Need help with failed display (Microwave Repair)
by Guest 8/6/2023 9:04:42 AM(UTC)
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 5/5/2023 2:39:37 PM(UTC)
Need help with diagnosis - bake and broil not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/7/2022 6:29:02 AM(UTC)
Frigidiare Gallery High temp alert. Need help troubleshooting. (Refrigerator & Freezer Repair)
by GregWood 8/28/2022 7:47:25 PM(UTC)
Need help narrow down oven problem (Oven Repair (including Ranges and Cooktops))
by Guest 7/4/2022 6:46:54 PM(UTC)
Need help with repair of Kenmore built in oven door handle repair 91141065791 (Oven Repair (including Ranges and Cooktops))
by Notacook 10/27/2021 5:49:46 PM(UTC)
need help with model number (Oven Repair (including Ranges and Cooktops))
by onadraw 7/2/2021 10:01:12 AM(UTC)
Need Help With Frigidaire FGHS2631PF4A (Refrigerator & Freezer Repair)
by BrianR1 3/2/2021 1:46:20 PM(UTC)
I need help with literary work (General Talk)
by Fackbey201350 4/17/2020 7:36:42 AM(UTC)
GE WASHER NEED HELP(SOLVED) (Dishwasher Repair)
by Covenant29204 9/8/2019 9:51:57 AM(UTC)
Whirlpool Microwave Door Sensor Part & Diagram? Need help (Microwave Repair)
by ellie0704 4/8/2019 8:26:28 AM(UTC)
NEED HELP replacing THERMISTOR & FUSE assembly (Washer Repair)
by leastam 1/28/2019 2:06:26 PM(UTC)
