Casey0053
#1 Posted : 15 years ago
Casey0053
The outside top and sides of the refrigerator and freezer are hot to the touch and the refrigerator is not cooling that great. The temp is set all the way up. Everything freezes in the freezer except ice cream. It only gets mid way. Any suggestions before I call a repairman? I would like an idea of the problem so I won't get taken. Thanks for any help.
#2 Posted : 15 years ago
Could not find a BW6, following is for a BW7, parts breakdown.
Replacement parts for FRIGIDAIRE FRT21G4BW7 Frigidaire/refrigerator | AppliancePartsPros.com
A hot case is usually due to dirty condenser coils under the unit or the condenser fan not running.
Casey0053
#3 Posted : 15 years ago
Casey0053
Thank you. I cleaned it and will wait and see. I also verified on the inside plate and it is a BW6.
Need Help Identifying Part Manufacturer (Oven Repair (including Ranges and Cooktops))
by anonymous24 11 months ago
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 12 months ago
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox about a year ago
Need help with failed display (Microwave Repair)
by Guest 2 years ago
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 2 years ago
Need help with diagnosis - bake and broil not working (Oven Repair (including Ranges and Cooktops))
Frigidiare Gallery High temp alert. Need help troubleshooting. (Refrigerator & Freezer Repair)
by GregWood 3 years ago
Need help narrow down oven problem (Oven Repair (including Ranges and Cooktops))
by Guest 3 years ago
Need help with repair of Kenmore built in oven door handle repair 91141065791 (Oven Repair (including Ranges and Cooktops))
by Notacook 3 years ago
need help with model number (Oven Repair (including Ranges and Cooktops))
by onadraw 4 years ago
Need Help With Frigidaire FGHS2631PF4A (Refrigerator & Freezer Repair)
by BrianR1 4 years ago
I need help with literary work (General Talk)
by Fackbey201350 5 years ago
GE WASHER NEED HELP(SOLVED) (Dishwasher Repair)
by Covenant29204 6 years ago
Whirlpool Microwave Door Sensor Part & Diagram? Need help (Microwave Repair)
by ellie0704 6 years ago
NEED HELP replacing THERMISTOR & FUSE assembly (Washer Repair)
by leastam 6 years ago
