Dryer works but don't heat. I was told it was the thermostat. How would I replace it myself?
Originally Posted by: telena  Dryer works but don't heat. I was told it was the thermostat. How would I replace it myself? Telena, There are two thermostats and two thermal fuses in you heat circuit, besides, other components. Being that this is an electric dryer, the most likely situation is a broken heat element(more common than a thermostat or thermal fuse). You will need to dismantle the machine to access most of the components, and you need a meter to test circuits and components. Let us know when you have the tools and meter and we can walk you through it, and get it fixxed. :) :) :)
