Gary Hopkins
#1 Posted : Friday, September 19, 2008 1:10:51 PM(UTC)
Gary Hopkins
Dryer does not heat but dryer runs. Breakers are ok. have removed screews of back of dryer but unable to remove back.
libertyappl
#2 Posted : Friday, September 19, 2008 1:22:33 PM(UTC)
libertyappl
You have to remove the front panel on your model, the back isn't a removable part. raise the top and remove the front panel to get to the thermostats
nat
SublimeMasterJW
#3 Posted : Friday, September 19, 2008 3:23:49 PM(UTC)
SublimeMasterJW
You flip down the lower front panel to access this models innards. It is known as a princess series. Their are 2 fuses. One is located on the heating element and another is behind the filter housing . To access it you must remove the filter housing which is fairly easy. Any of these parts that are open (no continuity) will cause the heating element to not function at all. look for these puppys : zoom.jpg
SublimeMasterJW attached the following image(s):
SublimeMasterJW
#4 Posted : Friday, September 19, 2008 3:27:48 PM(UTC)
SublimeMasterJW
You may find these types : rust buster.jpg as well. Remember there 2 of these in this dryer. Failure to clean any lint or blockages will cause these fuses to blow again right away so you need to clean out the funk.:D
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
