3 Pages123>
Tunaman
#1 Posted : Tuesday, September 16, 2008 10:55:45 AM(UTC)
Tunaman
The agitator barely moves. With a slight bit of hand preasure on the top of it, I can feel it trying to move.
How can I repair this?
:confused:
libertyappl
#2 Posted : Tuesday, September 16, 2008 11:00:13 AM(UTC)
libertyappl
Does the bottom part of the agitator move?
Nat
Tunaman
#3 Posted : Tuesday, September 16, 2008 11:07:00 AM(UTC)
Tunaman
Not Really.
libertyappl
#4 Posted : Tuesday, September 16, 2008 11:09:15 AM(UTC)
libertyappl
Does it make any strange sounds?
libertyappl
#5 Posted : Tuesday, September 16, 2008 11:14:19 AM(UTC)
libertyappl
Also does it spin and drain?
nat
Tunaman
#6 Posted : Tuesday, September 16, 2008 12:27:18 PM(UTC)
Tunaman
The washing machine works fine as far as the cycles, ie., spin, drain and etc. The agitator simply doesn't agitate the way it used to. In an older washing machine I used to have, there were these plastic gear-like parts that I had to replace to correct a similar problem.
libertyappl
#7 Posted : Tuesday, September 16, 2008 12:44:53 PM(UTC)
libertyappl
They are called agitator dogs part # 80040. which might be part of the problem, but if bottom isn't workign right may need to look at the grooves in the bottom of the agitator.
Nat
Tunaman
#8 Posted : Wednesday, September 17, 2008 6:09:01 AM(UTC)
Tunaman
CORRECTION!
Upon
Tunaman
#9 Posted : Wednesday, September 17, 2008 6:12:11 AM(UTC)
Tunaman
Upon further inspection, the bottom section of the agitator works great. It is the upper section that does not. Earlier I stated that it didn't. Yes, the bottom of the agitator moves.
libertyappl
#10 Posted : Wednesday, September 17, 2008 7:05:03 AM(UTC)
libertyappl
Then you are going to need those agitator dogs 80040. Do you wash a lot of heavy stuff? If so you may want to lighten the loads.
Nat
3 Pages123>
