Need some detail on how to install replacement light bulb in microwave oven
Originally Posted by: Roes ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Need some detail on how to install replacement light bulb in microwave oven Roes, I take for granted, you mean the oven cavity light, not the cooktop lights. Here is the part number and the instructions from the service manual. Good Luck, :) :) :) Part number: AP4057187
Grille The top full-width grille is removable for service to some components, such as: humidity sensor, oven light, door removal, flame sensor, vent motor capacitor, fuse, control panel, and stirrer motor (some models). Grille Removal 1. Disconnect power to oven. 2. Remove screws located in front on top of microwave securing grille 3. Pull outward on the top portion of the grille releasing the tabs. 4. Reassemble in reverse order.Light Socket 1. Disconnect power to oven. 2. Remove Grille (see "Grille" procedure). 3. Remove screws securing bulb holder. 4. Remove light bulb and socket. 5. Disconnect wire terminal plug. 6. Replace and reassemble in reverse order
