:confused: It seems to run, but there is no loud noise anymore. The compressor tank is hot, the fan behind runs well. I do not knowif the motor is working or not and since there no loud noise is the motor not workin or is the compressor that has stopped. the temp in the freezer is 45 and in the refrig is above 50. Please answerd ASAP I am desparate and cannot afford to buy a new one. Thank you:cool:
If the compressor is running, it should make a distinctive whine noise and the entire condenser should be warm. If not, pull the side cover off the compressor and check the start device plugged into the compressor. These usually do not fail, but if it is burnt, replace it AP3156242
Originally Posted by: richappy  If the compressor is running, it should make a distinctive whine noise and the entire condenser should be warm. If not, pull the side cover off the compressor and check the start device plugged into the compressor. These usually do not fail, but if it is burnt, replace it AP3156242 Than you, the compressor is HOT fun working, refrig at 46deg constant, running all the time. control temp set at max the condenser coil warm, above room temp. Please help.Maybe a braker is not closing or swicth has failed?
Pull out the back panel of the freezer and describe the frost pattern.
