jaireb
#1 Posted : 15 years ago
jaireb
:confused: It seems to run, but there is no loud noise anymore. The compressor tank is hot, the fan behind runs well.
I do not knowif the motor is working or not and since there no loud noise is the motor not workin or is the compressor that has stopped.
the temp in the freezer is 45 and in the refrig is above 50.
Please answerd ASAP I am desparate and cannot afford to buy a new one.
Thank you:cool:
#2 Posted : 15 years ago
If the compressor is running, it should make a distinctive whine noise and the entire condenser should be warm. If not, pull the side cover off the compressor and check the start device plugged into the compressor. These usually do not fail, but if it is burnt, replace it AP3156242
jaireb
#3 Posted : 15 years ago
jaireb
Than you, the compressor is HOT fun working, refrig at 46deg constant, running all the time. control temp set at max
the condenser coil warm, above room temp. Please help.Maybe a braker is not closing or swicth has failed?
#4 Posted : 15 years ago
Pull out the back panel of the freezer and describe the frost pattern.
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 11 months ago
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco about a year ago
GE side by side water and ice not working (General Talk)
by Guest 2 years ago
GE Side by side fridge; control panel blank; not cooling (Refrigerator & Freezer Repair)
by peteror 3 years ago
GE side by side PSS26SGPA SS (Refrigerator & Freezer Repair)
by Guest 3 years ago
GE side by side clicks once by compressor then once on board. (Refrigerator & Freezer Repair)
by Schaanman 3 years ago
GE side by side model GSS25KSTASS ice maker auger continues to run (Refrigerator & Freezer Repair)
by RodneyS 4 years ago
GE Side by Side Freezer 25 degrees warmer than set-point (Refrigerator & Freezer Repair)
by reese600 4 years ago
GE side by side starts and stops (Refrigerator & Freezer Repair)
by SethL 4 years ago
GE Side by Side - Water/Ice Dispense (Refrigerator & Freezer Repair)
by USS Pogy 4 years ago
GE Side by side GSHS6LGBBHSS (Refrigerator & Freezer Repair)
by Ksutherland 5 years ago
GE side by side refregator does not start (Refrigerator & Freezer Repair)
by patel_bhavesh100 6 years ago
GE side by side, uneven cooling (Refrigerator & Freezer Repair)
by GLMace 6 years ago
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 6 years ago
GE side by side, sporadic water and ice dispensing (Refrigerator & Freezer Repair)
by Ramski00 6 years ago
