jaireb
#1 Posted : Tuesday, August 31, 2010 10:48:04 PM(UTC)
jaireb
:confused: It seems to run, but there is no loud noise anymore. The compressor tank is hot, the fan behind runs well.
I do not knowif the motor is working or not and since there no loud noise is the motor not workin or is the compressor that has stopped.
the temp in the freezer is 45 and in the refrig is above 50.
Please answerd ASAP I am desparate and cannot afford to buy a new one.
Thank you:cool:
#2 Posted : Wednesday, September 1, 2010 2:42:14 AM(UTC)
If the compressor is running, it should make a distinctive whine noise and the entire condenser should be warm. If not, pull the side cover off the compressor and check the start device plugged into the compressor. These usually do not fail, but if it is burnt, replace it AP3156242
jaireb
#3 Posted : Wednesday, September 1, 2010 11:04:09 AM(UTC)
jaireb
Than you, the compressor is HOT fun working, refrig at 46deg constant, running all the time. control temp set at max
the condenser coil warm, above room temp. Please help.Maybe a braker is not closing or swicth has failed?
#4 Posted : Thursday, September 2, 2010 2:33:48 PM(UTC)
Pull out the back panel of the freezer and describe the frost pattern.
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco 1/11/2024 10:04:34 AM(UTC)
GE side by side water and ice not working (General Talk)
by Guest 10/8/2022 6:17:31 AM(UTC)
GE Side by side fridge; control panel blank; not cooling (Refrigerator & Freezer Repair)
by peteror 3/20/2022 10:14:32 PM(UTC)
GE side by side PSS26SGPA SS (Refrigerator & Freezer Repair)
by Guest 1/23/2022 3:19:31 AM(UTC)
GE side by side clicks once by compressor then once on board. (Refrigerator & Freezer Repair)
by Schaanman 1/23/2022 2:03:33 AM(UTC)
GE side by side model GSS25KSTASS ice maker auger continues to run (Refrigerator & Freezer Repair)
by RodneyS 5/30/2021 2:59:27 PM(UTC)
GE Side by Side Freezer 25 degrees warmer than set-point (Refrigerator & Freezer Repair)
by reese600 1/21/2021 11:39:19 AM(UTC)
GE side by side starts and stops (Refrigerator & Freezer Repair)
by SethL 12/19/2020 6:58:00 AM(UTC)
GE Side by Side - Water/Ice Dispense (Refrigerator & Freezer Repair)
by USS Pogy 11/5/2020 4:08:04 AM(UTC)
GE Side by side GSHS6LGBBHSS (Refrigerator & Freezer Repair)
by Ksutherland 5/16/2020 10:05:38 AM(UTC)
GE side by side refregator does not start (Refrigerator & Freezer Repair)
by patel_bhavesh100 9/12/2019 5:32:28 AM(UTC)
GE side by side, uneven cooling (Refrigerator & Freezer Repair)
by GLMace 2/28/2019 2:46:16 PM(UTC)
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 1/3/2019 9:31:00 PM(UTC)
GE side by side, sporadic water and ice dispensing (Refrigerator & Freezer Repair)
by Ramski00 11/25/2018 12:13:04 PM(UTC)
