Model LET7848AQ2 I ORDERED A NEW TIMER BUT THE CONNECTION DOES NOT MATCH MY ORIGINAL ONE. PLEASE LET ME KNOW IF I ORDERED THE CORRECT ONE OR NOT AND IF I DID WHAT SHOULD DO.
Your timer part should be part # AP2973903 according to your model number. What exactly was your dryer doing? Nat
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
My Part Number Is 3397273 Which Is Look Like The Ap2973903. And I Have Not Connected Yet. Becase The Plugs Are Differnt The Old One Has 2 Plugs At The Back The One Peace Wire Jumps Over Them, But The New One Has Only One Plug At The Back And One Plug Conected To Silver Metal.
That is the correct part there should be directions with the timer for the adjustment. Nat BTW - I only use the quick reply button when making replies
There was not a directions with the timer for the adjustment.
See if this helps any. Nat
the diagram is for the old timer. at the buttom of the diagram there is wire "jumper " grey or tan and the middle connect is not there. insted there is connection added to the silver part of the timer. every thing else match.
no you were not able to help me.
The New Timer Shows Part Number As "3397273b. The Old One Is "3397273".
