2 Pages12>
esi
#1 Posted : Tuesday, September 9, 2008 10:30:45 PM(UTC)
esi
Model LET7848AQ2
I ORDERED A NEW TIMER BUT THE CONNECTION DOES NOT MATCH MY ORIGINAL ONE. PLEASE LET ME KNOW IF I ORDERED THE CORRECT ONE OR NOT AND IF I DID WHAT SHOULD DO.
libertyappl
#2 Posted : Wednesday, September 10, 2008 8:07:14 AM(UTC)
libertyappl
Your timer part should be part # AP2973903 according to your model number.
What exactly was your dryer doing?
Nat
esi
#3 Posted : Wednesday, September 10, 2008 8:26:37 AM(UTC)
esi
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
esi
#4 Posted : Wednesday, September 10, 2008 8:33:22 AM(UTC)
esi
My Part Number Is 3397273 Which Is Look Like The Ap2973903.
And I Have Not Connected Yet. Becase The Plugs Are Differnt The Old One Has 2 Plugs At The Back The One Peace Wire Jumps Over Them, But The New One Has Only One Plug At The Back And One Plug Conected To Silver Metal.
libertyappl
#5 Posted : Wednesday, September 10, 2008 8:40:22 AM(UTC)
libertyappl
That is the correct part there should be directions with the timer for the adjustment.
Nat
BTW - I only use the quick reply button when making replies
esi
#6 Posted : Wednesday, September 10, 2008 10:43:51 AM(UTC)
esi
There was not a directions with the timer for the adjustment.
libertyappl
#7 Posted : Wednesday, September 10, 2008 10:47:17 AM(UTC)
libertyappl
See if this helps any.
Nat
File Attachment(s):
Wiring Sheet - 3401725.pdf (44kb) downloaded 30 time(s).
esi
#8 Posted : Wednesday, September 10, 2008 11:15:59 AM(UTC)
esi
the diagram is for the old timer.
at the buttom of the diagram there is wire "jumper " grey or tan and the middle connect is not there. insted there is connection added to the silver part of the timer. every thing else match.
esi
#9 Posted : Thursday, September 11, 2008 6:15:03 AM(UTC)
esi
no you were not able to help me.
esi
#10 Posted : Thursday, September 11, 2008 11:19:20 AM(UTC)
esi
The New Timer Shows Part Number As "3397273b.
The Old One Is "3397273".
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Dryer Timer Humming (Dryer Repair)
by terzolino 4/6/2023 10:18:16 AM(UTC)
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 3/19/2021 9:04:39 AM(UTC)
Dryer timer shorting - help me verify my rationale (Dryer Repair)
by jeromio 1/29/2020 6:51:31 PM(UTC)
Whirlpool dryer timer knob (Dryer Repair)
by robertjhebert 10/27/2019 8:50:18 AM(UTC)
Kenmore dryer timer or no timer (Dryer Repair)
by Jester1x 10/25/2019 8:47:13 PM(UTC)
Whirlpool dryer timer won't stop running. (Dryer Repair)
by ppipowerclass 4/2/2018 2:18:22 PM(UTC)
Wiring Help On GE Dryer Timer (Dryer Repair)
by Kierancypher 6/16/2017 11:00:27 AM(UTC)
Dryer Timer Compatibility (Dryer Repair)
by Paulvolter 5/28/2017 6:48:02 PM(UTC)
dryer timer release brackets (Dryer Repair)
by lcolquitt 5/24/2017 2:50:20 PM(UTC)
Kenmore Gas Dryer Timer (Dryer Repair)
by keepitfromthedump 5/24/2017 2:18:27 PM(UTC)
dryer timer will not advance (Dryer Repair)
by Jlb86 2/24/2017 4:24:03 PM(UTC)
2 Pages12>
