I recieved error code F2 E6 and was told by Whirlpool to replace the the control board which I did.
After replacing that part thern I get error codes F2 E1. Which states that I have to replace the Keypad.
Is this out of the ordinary that both parts become defective at the same time? What would cause something like this? If I replace the keypad will this fix the problem or should I be looking for something else.
I would really like to order the parts so we can use the oven.
Thanks Ed
Check the conntectors to the keypad they sometimes get corrosion on thm causing the same effect. Nat
I checked the flat cable ohmage wise and there was continuity between the diodes on the control board and the flat cable fingers.
From the fingers to the keypad I cannot check except from finger to finger but I have no idea what the ohms readings would be. Any ideas?
It i possible that a power surge could have affected both parts. If memory serves......just check for continuity. I'll try t do some research and see what I can find for you. Nat
Originally Posted by: libertyappl  It i possible that a power surge could have affected both parts. If memory serves......just check for continuity. I'll try t do some research and see what I can find for you. Nat Nat Did you find anything out about this? Thanks Ed
Not yet Ed my main computer is having some additional progams installed and I'm back to my old PC... :o( Hopefully will get that all done Soon!!!!!!!!!! Nat
