brummel
#1 Posted : Tuesday, September 9, 2008 10:55:52 AM(UTC)
brummel
I recieved error code F2 E6 and was told by Whirlpool to replace the the control board which I did.
After replacing that part thern I get error codes F2 E1. Which states that I have to replace the Keypad.
Is this out of the ordinary that both parts become defective at the same time? What would cause something like this? If I replace the keypad will this fix the problem or should I be looking for something else.
I would really like to order the parts so we can use the oven.
Ed
libertyappl
#2 Posted : Tuesday, September 9, 2008 11:50:59 AM(UTC)
libertyappl
Check the conntectors to the keypad they sometimes get corrosion on thm causing the same effect.
Nat
brummel
#3 Posted : Tuesday, September 9, 2008 6:32:38 PM(UTC)
brummel
I checked the flat cable ohmage wise and there was continuity between the diodes on the control board and the flat cable fingers.
From the fingers to the keypad I cannot check except from finger to finger but I have no idea what the ohms readings would be. Any ideas?
libertyappl
#4 Posted : Tuesday, September 9, 2008 6:39:16 PM(UTC)
libertyappl
It i possible that a power surge could have affected both parts. If memory serves......just check for continuity. I'll try t do some research and see what I can find for you.
Nat
brummel
#5 Posted : Tuesday, September 23, 2008 9:47:48 AM(UTC)
brummel
Nat
Nat
Did you find anything out about this?
Ed
libertyappl
#6 Posted : Tuesday, September 23, 2008 11:10:03 AM(UTC)
libertyappl
Not yet Ed my main computer is having some additional progams installed and I'm back to my old PC... :o(
Hopefully will get that all done Soon!!!!!!!!!!
Nat
Guest (4)
LG Dryer DLGY1702VE no error codes (Dryer Repair)
by Lisssasue 7/17/2023 10:41:37 AM(UTC)
Kenmore Elite Washer error codes (Washer Repair)
by Cenzo 3/23/2023 12:58:19 PM(UTC)
Kenmore washer error codes (Washer Repair)
by Guest 3/5/2023 7:00:21 AM(UTC)
GE Refrigerator diagnostic mode error codes (Refrigerator & Freezer Repair)
by Guest 1/22/2023 10:11:53 AM(UTC)
Kennmore Elite Top Load Washer - MHK62125813 - Error Codes (Washer Repair)
by maxxam864 1/4/2023 12:11:00 PM(UTC)
Error Codes on lg dishwasher LDF5545st (Dishwasher Repair)
by Guest 7/25/2022 10:57:38 AM(UTC)
GE GTW330ASK1WW odd behavior and multiple error codes for lid lock (Washer Repair)
by petermbooth 6/3/2022 5:11:39 PM(UTC)
Frigidaire gallery error codes (Oven Repair (including Ranges and Cooktops))
by Guest 5/9/2021 9:55:31 AM(UTC)
Does anyone know how to clear error codes on Bosch Washer (Washer Repair)
by bmoney37 6/12/2020 9:35:37 PM(UTC)
Whirlpool Duet Steam Error Codes (Dryer Repair)
by etamunupe 3/28/2020 5:09:00 AM(UTC)
front load washer error codes (Washer Repair)
by scully61 11/19/2018 5:44:51 AM(UTC)
Jenn-air Gas Range Error codes (Oven Repair (including Ranges and Cooktops))
by uncledave11 3/29/2018 11:48:39 AM(UTC)
No error codes (Oven Repair (including Ranges and Cooktops))
by docnpat 2/16/2018 8:08:11 PM(UTC)
Kitchen aid not cleaning dishes have error codes (Dishwasher Repair)
by Randall1803 11/13/2016 6:55:35 PM(UTC)
Help with Maytag Washing Machine Error Codes (Washer Repair)
by Gjohnlue 7/8/2016 3:58:06 PM(UTC)
