Washer will wash and drain but will not spin.
Hi, I seem to have the same problem :mad: on same machine 417.44152-400. The tech sheet inside the cabinet describes how to enter a diagnostic routine. Mine shows that it will indeed spin, but during a regular cycle the pump just keeps pumping and will not advance to spin. Is there a sensor which indicates that the tub is empty and ready for spin?
dagwood37, The sensor you mention is the motor resistor, which is located on the back of the motor. Check the connections, make sure they are secure. Nat
