timinpeyton
#1 Posted : Saturday, September 6, 2008 8:50:20 AM(UTC)
timinpeyton
Washer will wash and drain but will not spin.
dagwood37
#2 Posted : Monday, September 22, 2008 1:24:24 PM(UTC)
dagwood37
Hi, I seem to have the same problem :mad: on same machine 417.44152-400. The tech sheet inside the cabinet describes how to enter a diagnostic routine. Mine shows that it will indeed spin, but during a regular cycle the pump just keeps pumping and will not advance to spin. Is there a sensor which indicates that the tub is empty and ready for spin?
libertyappl
#3 Posted : Monday, September 22, 2008 1:33:27 PM(UTC)
libertyappl
dagwood37,
The sensor you mention is the motor resistor, which is located on the back of the motor. Check the connections, make sure they are secure.
Nat
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
GE washer will not spin (Washer Repair)
by MS104 5/10/2016 4:34:48 PM(UTC)
Maytag Atlantis Washer will not spin (Washer Repair)
by lvavis 8/26/2015 7:56:10 PM(UTC)
by howard6168 7/5/2015 5:47:41 AM(UTC)
Kenmore 800 Washer will not spin (Washer Repair)
by AnneKenzie 6/18/2015 12:01:29 PM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
washer will not spin out (Washer Repair)
by kdwarren16yrs 12/27/2014 6:42:50 AM(UTC)
ge profile washer will not spin (Washer Repair)
by ron dog 11/29/2014 5:27:31 PM(UTC)
Washer will not spin/drain (work) (Washer Repair)
by dupdc 8/20/2014 2:50:08 AM(UTC)
Whirlpool Cabrio Washer Will Not Spin (Washer Repair)
by pacdave 5/7/2014 6:40:52 PM(UTC)
