sunlake
#1 Posted : Thursday, September 4, 2008 2:23:53 PM(UTC)
sunlake
My Kenmore gas dryer does not complete the drying cycle and therefore the clothes do not get dry. My dryer ignighter fires up ok but during the drying cycle it tries to reignight but fails to start burning. The glow plug starts to glow but does not ignight. I would like to know the best way to get to the burner system. I don't have a diagram of the best access entry method. I am considering replacing the 2 coils unless someone has a better solution to my problem.
misterfixall
#2 Posted : Thursday, September 4, 2008 5:42:24 PM(UTC)
misterfixall
replace coils, remove 2 screws from screen cover. use slot screw driver to pry up top , remove 2 screw on either side of front panel+lift away off bottom clips, burner will be exposed. if you have purchased coils you will know where they go. G-L
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Kenmore gas dryer overheating and shutting down in permanent press setting (Dryer Repair)
by Actonite 8/14/2022 4:57:32 PM(UTC)
Kenmore Gas Dryer wont stay hot (Dryer Repair)
by johnmeyers 2/12/2021 2:05:37 PM(UTC)
Kenmore Gas Dryer - No Heat (Dryer Repair)
by smackover 10/6/2018 5:55:17 PM(UTC)
Kenmore Gas Dryer Timer (Dryer Repair)
by keepitfromthedump 5/24/2017 2:18:27 PM(UTC)
Kenmore gas dryer won' dry clothes all the way (Dryer Repair)
by ggarnett 1/2/2017 7:51:16 AM(UTC)
Kenmore Gas dryer wnot heat (Dryer Repair)
by wardm6 7/9/2016 11:30:51 AM(UTC)
kenmore gas dryer runs only when push to start is pressed in (Dryer Repair)
by carlosjbb 12/12/2015 11:34:10 PM(UTC)
Kenmore gas dryer heats intermittently (Dryer Repair)
by Nordillaca 12/12/2015 7:33:46 AM(UTC)
Kenmore Gas Dryer intermittent (Dryer Repair)
by diyeng 2/24/2014 10:01:39 AM(UTC)
Kenmore Gas Dryer won't Heat (Dryer Repair)
by rboysen 2/5/2014 5:57:38 AM(UTC)
electrolux/kenmore gas dryer fault (Dryer Repair)
by iclad 1/28/2014 12:53:59 PM(UTC)
No heat - Kenmore gas dryer (Dryer Repair)
by Brian Effinger 11/7/2013 1:11:12 PM(UTC)
Kenmore Gas dryer, no heat control (Dryer Repair)
by iowacows 8/13/2013 4:18:50 PM(UTC)
