John Kulju
#1 Posted : Wednesday, September 3, 2008 2:21:59 PM(UTC)
John Kulju
Our electric dryer does not dry the clothing fully in the drying cycle.
What could be the problem(s). Seems as if the drying cycle is running properly.
douglas j. hoffman
#2 Posted : Wednesday, September 3, 2008 4:51:34 PM(UTC)
douglas j. hoffman
John sounds like a blocked dryer vent hose ?
John Kulju
#3 Posted : Thursday, September 4, 2008 4:04:38 PM(UTC)
John Kulju
We checked the dryer hose and it is clean and clear. No bird nests or problems with the dryer hose and vent. Seems like the temperature fluctuates when you put your hand outside the dryer vent. Temperature is warm then hot then???? Any ideas what the problem may be
mcgee139
#4 Posted : Friday, September 5, 2008 7:56:13 AM(UTC)
mcgee139
Hello you said that you checked the venting but did you take the back of the dryer off and check the vent in their (that is were they clogged a lot) and for the hot cold temps out of the outlet it is going to do that they have a thermal disk that turns it on at around 135 and off around 195
You should have some one in to do a thermal check
good luck
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
Belarus Guest 5/20/2024 5:37:01 AM(UTC)
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
