Our electric dryer does not dry the clothing fully in the drying cycle. What could be the problem(s). Seems as if the drying cycle is running properly.
Originally Posted by: John Kulju  Our electric dryer does not dry the clothing fully in the drying cycle. What could be the problem(s). Seems as if the drying cycle is running properly. John sounds like a blocked dryer vent hose ?
We checked the dryer hose and it is clean and clear. No bird nests or problems with the dryer hose and vent. Seems like the temperature fluctuates when you put your hand outside the dryer vent. Temperature is warm then hot then???? Any ideas what the problem may be
Hello you said that you checked the venting but did you take the back of the dryer off and check the vent in their (that is were they clogged a lot) and for the hot cold temps out of the outlet it is going to do that they have a thermal disk that turns it on at around 135 and off around 195
You should have some one in to do a thermal check
good luck
