Is the thermistor supposed to show continuity if you test it with a continuity tester? I checked the thermostats and those showed continuity but then the thermistor did not. What is the function of the thermistor?
Yes the dryer thermistor needs to have specific amount of resistance at a given temperature or the EVENHEAT control board will not allow the motor relay to close to keep the dryer running. Here are the components related to the symptom: EVENHEAT control board Motor relay Thermistor Below is the resistance chart of the thermistor at different temperatures: At 50 degrees Fahrenheit the thermistor should ohm at 19.9 K ohms At 60 degrees 15.3 k ohms 70 degrees 11.9 K ohms 80 degrees 9.2 K ohms 90 degrees 7.4 K ohms 100 degrees 5.7 K ohms 110 degrees 4.7 K ohms 120 degrees 3.7 K ohms 130 degrees 3.1 K ohms 140 degrees 2.5 K ohms
