raptor01
#1 Posted : Friday, August 29, 2008 1:44:51 PM(UTC)
raptor01
Is the thermistor supposed to show continuity if you test it with a continuity tester? I checked the thermostats and those showed continuity but then the thermistor did not. What is the function of the thermistor?
kayakcrzy
#2 Posted : Saturday, August 30, 2008 6:04:31 AM(UTC)
kayakcrzy
Replace the thermister. It should have continuity. Tom ApplianceEducator.com
Reinaldo
#3 Posted : Monday, January 14, 2013 4:25:07 PM(UTC)
Reinaldo
Yes the dryer thermistor needs to have specific amount of resistance at a given temperature or the EVENHEAT control board will not allow the motor relay to close to keep the dryer running.
Here are the components related to the symptom:
Motor relay
Thermistor
Below is the resistance chart of the thermistor at different temperatures:
At 50 degrees Fahrenheit the thermistor should ohm at 19.9 K ohms
At 60 degrees 15.3 k ohms
70 degrees 11.9 K ohms
80 degrees 9.2 K ohms
90 degrees 7.4 K ohms
100 degrees 5.7 K ohms
110 degrees 4.7 K ohms
120 degrees 3.7 K ohms
130 degrees 3.1 K ohms
140 degrees 2.5 K ohms
LG Dryer Heater Thermistor Error (Dryer Repair)
by Guest 11/16/2022 8:37:57 AM(UTC)
Bad fresh food thermistor? (Refrigerator & Freezer Repair)
by barlav 10/1/2022 5:01:58 AM(UTC)
How do I access GE Evaporator Fan, coils, thermistor, etc (Refrigerator & Freezer Repair)
by Yari 8/4/2022 1:48:47 PM(UTC)
LG WM3050C thermistor/heating element help (Washer Repair)
by Guest 10/2/2021 5:29:07 AM(UTC)
Viking Thermistor Problem (Refrigerator & Freezer Repair)
by TDK-2020 10/21/2020 8:52:41 AM(UTC)
Maytag MRT311FFFZ00 thermistor chart & diagnostics mode (Refrigerator & Freezer Repair)
by scottaobe 2/1/2019 8:35:11 AM(UTC)
NEED HELP replacing THERMISTOR & FUSE assembly (Washer Repair)
by leastam 1/28/2019 2:06:26 PM(UTC)
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 1/3/2019 9:31:00 PM(UTC)
whirlpool GEX9868jt2. Was getting E1 error. replaced thermistor. Still getti (Dryer Repair)
by Garyatmaui 11/16/2017 12:19:47 PM(UTC)
how do i check the thermostat and thermistors (Refrigerator & Freezer Repair)
by ropeke 2/27/2017 2:25:42 PM(UTC)
E71 Outlet Control Thermistor (Dryer Repair)
by NaliKawi 2/2/2017 11:24:16 AM(UTC)
GE Hydrowave Top-Load... Thermistor Error... What Now? (Washer Repair)
by JoeyMac 8/12/2016 12:01:24 PM(UTC)
LG LSC27931ST Thermistor Part Number (Refrigerator & Freezer Repair)
by shackleford 11/12/2015 4:55:24 AM(UTC)
Duet E1 error after replacing thermistor (Dryer Repair)
by Steve8120 9/28/2014 6:48:28 PM(UTC)
Thermistor location(s) Refig and Freezer (Refrigerator & Freezer Repair)
by vincentjlawrence 9/15/2014 1:51:35 PM(UTC)
