njac37322
#1 Posted : Monday, August 16, 2010 11:25:02 AM(UTC)
njac37322
How do you change the timer? Is it something my husband can do as he is handy?
Thanks!
Joe / APP Team
#2 Posted : Monday, August 16, 2010 12:50:58 PM(UTC)
Joe / APP Team
Thanks!
There is a lot involved to change the timer, but a handy guy should be able to do it .
First thing is to shut the power off or unplug the line cord to the machine.
Remove the lower access panel of the dryer, (2 screws,1 screw on each corner of top of panel.
Remove the 4 screws(2 on each side of the control panel, coverred by the lower access panel).
Pull down and out on the bottom of the control console and un hook from the cabinet panel.
Now for the hard part.
On the back of the washer timer, where the timer shaft opening is located you will need to use a small, thin, screw driver or needle nose pliers, inside that "D" shaft opening you will see a retainer clip, you need to pry that clip out with the screwdriver or pull out with the needle nose pliers, and pull out on the timer knob, to remove the knob, then the skirt just slips off the remaining shaft housing.
You'll find a single screw beside the timer shaft housing,remove that screw and lift up on the locking tab on the backside of the timer/control console and slide the timer to the right to release the remaining tabs.
Remove the harness from the original timer, install it on the new timer and reverse procedure to install timer, control console, and panel.
re establish power to the unit and test.
Good Luck,
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
