Water dispenser functions fine,but, water not going into ice making tray. Filters are fine and arm in correct position for making ice. Any suggestions?:confused:
Originally Posted by: LJB6891X  Water dispenser functions fine,but, water not going into ice making tray. Filters are fine and arm in correct position for making ice. Any suggestions?:confused: First thing to check is, The fill tube to the icemaker, is it frozen or clogged? The harness in the upper door hinge(under the plastic cover), check it for loose wires or connections. The next check is, test the fill valve solenoids for 500 to 1000 ohms on each solenoid(that's still not a guarantee they work). With the cover off the front of the icemaker: With a meter check openings L to N for 120 VAC, for power into the icemaker. With an insulated jumper wire, insert into openings L and V (or N to V,on certain icemakers) and valves should open and icemaker should fill. If all the other checks are proper, and there is still no water to icemaker, suspect the fill valve(s). :) :) :)
I had the same problem with the same model Maytag refridge and followed your suggestions.
When I jumper the L and V openings the water tray filled. What part does that mean that I need to replace?
Thanks, Guy Mauro Brick, NJ
Originally Posted by: guymauro  I had the same problem with the same model Maytag refridge and followed your suggestions.
Thanks, Guy Mauro Brick, NJ Guy, With the valves activating with the jumper wire, and everything else checked OK, That would indicate a failed fill circuit in the ice maker control module. I reccomend you replace the icemaker assembly, Part number: AP4135008
Good Luck, :) :) :)
