LJB6891X
#1 Posted : Friday, August 13, 2010 10:09:27 AM(UTC)
LJB6891X
Water dispenser functions fine,but, water not going into ice making tray. Filters are fine and arm in correct position for making ice. Any suggestions?:confused:
Joe / APP Team
#2 Posted : Friday, August 13, 2010 11:57:14 AM(UTC)
Joe / APP Team
First thing to check is,
The fill tube to the icemaker, is it frozen or clogged?
The harness in the upper door hinge(under the plastic cover), check it for loose wires or connections.
The next check is, test the fill valve solenoids for 500 to 1000 ohms on each solenoid(that's still not a guarantee they work).
With the cover off the front of the icemaker:
With a meter check openings L to N for 120 VAC, for power into the icemaker.
With an insulated jumper wire, insert into openings L and V (or N to V,on certain icemakers) and valves should open and icemaker should fill.
If all the other checks are proper, and there is still no water to icemaker, suspect the fill valve(s).
guymauro
#3 Posted : Wednesday, November 24, 2010 4:16:15 PM(UTC)
guymauro
I had the same problem with the same model Maytag refridge and followed your suggestions.
When I jumper the L and V openings the water tray filled. What part does that mean that I need to replace?
Thanks,
Guy Mauro
Brick, NJ
Joe / APP Team
#4 Posted : Friday, November 26, 2010 5:08:08 AM(UTC)
Joe / APP Team
Thanks,
Guy Mauro
Brick, NJ
Guy,
With the valves activating with the jumper wire, and everything else checked OK,
That would indicate a failed fill circuit in the ice maker control module.
I reccomend you replace the icemaker assembly,
Part number: AP4135008
Good Luck,
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
