DBBromberg1
#1 Posted : Wednesday, September 12, 2007 7:52:36 AM(UTC)
DBBromberg1
I have been having a problem with the feed line for my ice maker freezing up at the ice maker I have to keep pulling it out from the back and running cold water in it to break up the ice, I am thinking because of the age of the fridge/freezer that I need to replace this tube but have been unable to find one?
Over this last weekend this happened and I did as I usually do I clear the ice from the tube and re-install it, then flip the arm to start the ice maker but now I am not getting any water to the ice maker it goes thru the cycle but I cannot get any water into the ice maker?
I have gone to the back of the unit and checked th line it is clear, I took the valve out and took it apart to make sure it is clear, re-asembled it and put it back in and still I am not getting any water to the ice maker?
Not sure if this is important but I do still have water on the door?
HELP!!!!!!!!!!!!!!!!!!!!!!!! please
#2 Posted : Thursday, September 13, 2007 1:57:43 AM(UTC)
Measure the freezer temperature and post. Go to the back and apply 115 volts to the icemaker water solenoid for about 9 seconds. Icemaker should fill up, if not, either a frozen water line to icemaker, or a bad water solenoid. Loosen the water line to the icemaker and check for water flow while applying voltage ,if none replace solenoid
DBBromberg1
#3 Posted : Thursday, September 13, 2007 5:35:46 AM(UTC)
DBBromberg1
Why would I need to measure the temperature in the freezer, you think the freezer is to cold and that is why the water is freezing at the ice maker in the line?
I said I cleared the lines so there is no plugged line, no frozen line.
OK update on this I have swapped around everything in every configuration between the valves and solenoids for the ice maker and the ones for water to the door (they are both in one housing) I can only get enough water to the ice maker to fill it up if I hook the solenoid for the door water to the ice maker lines and push on the lever for water on the door, I can watch the ice maker fill up.
To me what this seems like is there is a timer or something somewhere that tells the solenoid for the ice maker how long to run to fill the ice maker and this timer is not working right it is barely putting any water in the ice maker if any at all?
I really could use a hand with this anyone I am on SSI from a work injury (bad back) and do not really have the money to pay sears $50 to come look at it, also all this getting up and down to try these differnt combo-nations to try and figure out what is wrong is not helping my pain level either??
DBBromberg1
#4 Posted : Monday, September 24, 2007 7:30:03 AM(UTC)
DBBromberg1
This is still not working anyone? I had someone tell me to take a hair dryer and blow hot air on the ice maker for 5 minutes said that it should unstick what is stuck and start making ice I have done it two times and still nothing no water is getting to the ice maker when it cycles?
dentsx3
#5 Posted : Tuesday, July 10, 2012 5:19:37 PM(UTC)
dentsx3
Dear DB
I just replaced the duel pump for my icemaker water dispenser. After replacing, I reversed the plugs because the door was getting water but the ice tray was not. The filler on my unit was clogged with ice. I removed it and took out the clog. I filled the tray with water with the plugs reversed. Waiting for ice to freeze. I'll post if it works. I don't have a way to check if I need the entire tray replacement as you have done. I would suggest you check that pump as they do go bad.
Ice maker not getting water (Refrigerator & Freezer Repair)
by GLP 11/25/2016 7:19:47 PM(UTC)
by Mike Sasser 9/13/2016 11:25:07 AM(UTC)
by awashko 3/27/2014 8:13:43 AM(UTC)
ice maker not getting water (Refrigerator & Freezer Repair)
by jmr82 2/4/2013 10:01:51 PM(UTC)
by markplee@comcast.net 4/23/2012 7:58:24 AM(UTC)
KitchenAid Ice Maker Not Getting Water (Refrigerator & Freezer Repair)
by Steingraber 3/4/2012 12:49:54 PM(UTC)
Belarus redgtfour 2/19/2012 2:00:54 PM(UTC)
ge monogram - ice maker not getting water (Refrigerator & Freezer Repair)
by jmeurer 12/23/2011 8:41:41 PM(UTC)
Ice Maker not getting water (Refrigerator & Freezer Repair)
by garye 2/28/2010 4:02:28 AM(UTC)
Ice Maker Not getting water (Refrigerator & Freezer Repair)
by headtester 8/7/2009 8:27:51 AM(UTC)
Whirpool ice maker not getting water (Refrigerator & Freezer Repair)
by bjustice 5/6/2009 9:13:54 AM(UTC)
by bwseabee@yahoo.com 5/29/2008 3:21:32 AM(UTC)
Frigidaire Ice Maker not getting water & not working (Refrigerator & Freezer Repair)
by Salpal 9/26/2007 8:39:11 AM(UTC)
Ice maker not getting water. (Refrigerator & Freezer Repair)
by brandon58 7/30/2007 12:09:33 PM(UTC)
