How do you replace the water level switch on my Whirlpool Washer.
Groups: Expert
Originally Posted by: gdbrr1  How do you replace the water level switch on my Whirlpool Washer. Its not too bad of a job. There are two screws located at each end of the control panel on the back side. Loosen these until the control panel can be pulled forward about half an inch. Then the control panel just rotates up and back on it own hinges. Take the knob off the pressure switch and then disconnect the wires and pressure dome tube. There should be a tab you pull back and rotate the whole pressure switch until it is free of the control panel. Reverse to reassemble. part no. AP3890868
Thank for your reply. I'll be tackeling this job when the switch comes in.
