gdbrr1
#1 Posted : Monday, August 2, 2010 6:47:25 AM(UTC)
gdbrr1
How do you replace the water level switch on my Whirlpool Washer.
ThatGuy
#2 Posted : Monday, August 2, 2010 12:00:03 PM(UTC)
ThatGuy
Groups: Expert
United States
Its not too bad of a job. There are two screws located at each end of the control panel on the back side. Loosen these until the control panel can be pulled forward about half an inch. Then the control panel just rotates up and back on it own hinges. Take the knob off the pressure switch and then disconnect the wires and pressure dome tube. There should be a tab you pull back and rotate the whole pressure switch until it is free of the control panel. Reverse to reassemble.
part no. AP3890868
gdbrr1
#3 Posted : Monday, August 2, 2010 9:16:40 PM(UTC)
gdbrr1
Thank for your reply. I'll be tackeling this job when the switch comes in.
Limit Switch Replacement (Oven Repair (including Ranges and Cooktops))
by sandrair 11/17/2022 7:07:20 AM(UTC)
Avoid Siamesed Jenn-Air Cooktop Burners Upon Switch Replacement (Oven Repair (including Ranges and Cooktops))
by Tigertank84 2/26/2020 10:19:47 AM(UTC)
Whirlpool Door Switch Replacement- lost power to microwave (Microwave Repair)
by jk071604 3/23/2017 4:55:46 AM(UTC)
Switch Replacement Went Wrong (Oven Repair (including Ranges and Cooktops))
by gdavis8061 5/4/2015 5:32:41 PM(UTC)
Door switch replacement (Microwave Repair)
by pilotlite 10/1/2013 7:55:01 AM(UTC)
Infinite switch replacement (Oven Repair (including Ranges and Cooktops))
by J_T 9/14/2013 2:43:04 PM(UTC)
Overload relay switch replacement (Refrigerator & Freezer Repair)
by dmckenna 7/25/2013 5:16:48 PM(UTC)
range hood fan switch replacement (Heating, Ventilation, and Air Conditioning (HVAC))
by Teacher3rd 5/8/2013 10:49:15 AM(UTC)
Thermador Infinite Switch Replacement (Oven Repair (including Ranges and Cooktops))
by JLondon 4/16/2013 2:17:18 PM(UTC)
Help with GE Spacemaker Door Switch Replacement (Microwave Repair)
by ssgmail 2/24/2013 9:54:34 AM(UTC)
Affinity door switch replacement (Washer Repair)
by nancybillj 2/6/2013 7:32:59 AM(UTC)
Range Hood Fan Switch Replacement (Heating, Ventilation, and Air Conditioning (HVAC))
by Chiral88 1/15/2013 2:15:53 PM(UTC)
cooktop switch replacement (Oven Repair (including Ranges and Cooktops))
by Al Lutz 5/28/2012 6:40:12 PM(UTC)
High limit switch replacement question (Dryer Repair)
by justj1161 5/23/2012 9:27:50 AM(UTC)
infinite switch replacement (Oven Repair (including Ranges and Cooktops))
by inquisitive 5/18/2012 8:03:26 AM(UTC)
