My Crosley washer leaves behind liquid softener in tub after final rinse. What's wrong?
you probably have clogged holes on the dispenser locate the holes around the dispenser where it snaps on to agitator and use a small wire or q tip to unclog holes try mixing softener with water before adding to dispenser to make it thinner so it wont clog again
