pauline james
#1 Posted : Sunday, August 17, 2008 2:12:25 PM(UTC)
pauline james
My Crosley washer leaves behind liquid softener in tub after final rinse. What's wrong?
iamigor5@yahoo.com
#2 Posted : Sunday, August 17, 2008 5:06:52 PM(UTC)
iamigor5@yahoo.com
you probably have clogged holes on the dispenser locate the holes around the dispenser where it snaps on to agitator and use a small wire or q tip to unclog holes try mixing softener with water before adding to dispenser to make it thinner so it wont clog again
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
