kuziaks
#1 Posted : Friday, July 16, 2010 5:52:28 AM(UTC)
kuziaks
Pressure sensitive controls do not respond. Can not adjust temperature or fan speed. Have to pull the plug to shut the unit off.
kooler
#2 Posted : Monday, July 19, 2010 11:55:36 AM(UTC)
kooler
The main control board could be defective... If you don't want to shed out that many bucks for a new one then a cheaper substitute line voltage thermostat could be used that the air conditioner can be plugged into to turn it on and off.. I don't see a universal one in APPros list but they may have something that will work... Good luck cheers, kooler
Window A/C compressor won't turn off (Heating, Ventilation, and Air Conditioning (HVAC))
by nathanstrauss 7/25/2014 3:39:37 PM(UTC)
Window A/C HELP!! (Heating, Ventilation, and Air Conditioning (HVAC))
by jdpan 6/11/2013 6:08:12 PM(UTC)
window a/c (Heating, Ventilation, and Air Conditioning (HVAC))
by dominickt 6/30/2010 9:12:09 PM(UTC)
Whirlpool window a/c ACQ152xr1 (Heating, Ventilation, and Air Conditioning (HVAC))
by lauriem 6/23/2010 9:57:44 AM(UTC)
Window A/C No Longer Cooling (Heating, Ventilation, and Air Conditioning (HVAC))
by jdential 4/4/2010 1:51:23 PM(UTC)
Window a/c (Heating, Ventilation, and Air Conditioning (HVAC))
by thebates539 4/1/2010 1:21:32 PM(UTC)
Frigidaire Window A/C (Heating, Ventilation, and Air Conditioning (HVAC))
by b2jwh 11/3/2009 9:24:11 AM(UTC)
window A/C Compressor won't engage all the time. (Heating, Ventilation, and Air Conditioning (HVAC))
by aqpmedic 7/30/2008 12:18:48 PM(UTC)
Window A/c Working Half Efficiency (Heating, Ventilation, and Air Conditioning (HVAC))
by srbishoplx 8/6/2007 3:25:32 PM(UTC)
