MY WINDOW UNIT ALL OF SUDDEN STOPPED AND ITS GETTING POWER BUT THE ONLY BUTTON ON THE DIGITAL FRONT THAT WILL WORK IS THE TIMER BUT IT WILL NOT COME ON :confused: :confused: :confused: :confused:
Sorry, can't help much with this problem other than main control replacement which is probably not available... It may be time to replace the air conditioning unit altogether unless other controls could somehow be substituted... Not recommended here - good luck cheers
Window A/C compressor won't turn off
(Heating, Ventilation, and Air Conditioning (HVAC))
by nathanstrauss
7/25/2014 3:39:37 PM(UTC)
Window A/C HELP!!
by jdpan
6/11/2013 6:08:12 PM(UTC)
Window A/C
by kuziaks
7/16/2010 5:52:28 AM(UTC)
Whirlpool window a/c ACQ152xr1
by lauriem
6/23/2010 9:57:44 AM(UTC)
Window A/C No Longer Cooling
by jdential
4/4/2010 1:51:23 PM(UTC)
Window a/c
by thebates539
4/1/2010 1:21:32 PM(UTC)
Frigidaire Window A/C
by b2jwh
11/3/2009 9:24:11 AM(UTC)
window A/C Compressor won't engage all the time.
by aqpmedic
7/30/2008 12:18:48 PM(UTC)
Window A/c Working Half Efficiency
by srbishoplx
8/6/2007 3:25:32 PM(UTC)
