jdential
#1 Posted : Sunday, April 4, 2010 1:51:23 PM(UTC)
jdential
My through-the-wall room air conditioner (2 years old) turns on and blows air, but the compressor doesn't kick in for a few minutes and then, when it finally does, it will only run for a few minutes before shutting off and going back to just blowing ambient air. Any help appreciated.
Window AC
#2 Posted : Monday, April 19, 2010 4:51:03 PM(UTC)
Window AC
Could be a number of things. As far as thing that could be causing this that you could repair yourself. For starters I would check and make sure the outdoor coil is clean and the outdoor section is moving air as well. What size unit do you have?
icehouse
#3 Posted : Saturday, May 8, 2010 5:13:01 PM(UTC)
icehouse
Possible bad capacitor. :)
jhamp41
#4 Posted : Saturday, May 8, 2010 5:16:35 PM(UTC)
jhamp41
Compressor cutting out on the overload-could be pulling to many amps need a/c technician
